DAMTOYS Chinese People’s Armed Police Force Snow Leopard Commando Unit Team Leader
DAMTOYS
  • 78053
Body
  • Headsculpt
  • DAM 2.0 ACTION BADY
  • Mechanix Wear M-Pact Gen 1 Tactical Gloves x3
Uniform
  • T-Shirt (BLK)
  • BDU Top (Pixelated Tiger Stripes)
  • BDU Pants (Pixelated Tiger Stripes)
  • Cap Hat (Pixelated Tiger Stripes)
  • Belt
  • MAGNUM Stealth Force 8.0 Boots
  • QGF-03 Helmet w/ Side Rails
    • SureFire X200
    • TT Industries AN/PVS-14 MNVD w/ Arm Mount
      • Helmet NVG Mount
    • Oakley SI Straight Jacket Sunglasses
Vest and Pouches
  • Type 15 Body Armor
    • Throat Protector
    • Groin Protector
    • Rifle Mag Pouch x4
    • Double Pistol Mag Pouch
    • Double Grenade Pouch
    • Admin Pouch
    • Radio Pouch
  • Gas Mask Pouch
  • Medic Pouch
  • Canteen Pouch
  • US Military 1 QT Canteen
  • Casio G-SHOCK DW-9052 Digital Watch
  • Ballistic Shield
  • Elbowguards (BLK)
  • Arm Shields (BLK)
  • Shin and Knee Guards (BLK)
Communications
  • Vertex Standard VX 920 Series Radio
  • Norinco QBZ-95 :cn:
    • QBZ Mag 5.8×42mm (30rd) x3+1
    • Aimpoint CompM4
    • Aimpoint 3XMAG w/ Flip to Side Mount
    • SureFire M600 Ultra Scout Light
    • Scope Rail
    • Rails x2
    • Rifle Sling
  • China South Industries QCQ-05 :cn:
    • QCQ Mag 5.8×21mm (50rd) 3+1
    • Silencer
    • Sling
  • QSZ-92 :cn:
    • Mag 9×19mm (15rd) x2+1
    • Drop Leg Holster
  • Flahbang Grenade x2
  • Armed Police Force Special Troop Patch
  • Snow Leopard Commando Unit Shoulder Patch
  • Snow Leopard Commando Unit Patch
  • China Flag Patch
  • Insignia Patch
Out of the box with protective covers and the pixelated tiger stripe camo.
Here some reference for Chinese camo patterns
No idea who he is
IMG_6208
Uniform and basic clothing
Same padded underwear as the first Snow Leopard figure, but they provide additional waist padding and a black instead of a brown tee.
Top
Zipper is the only function
Right sleeve with velcro
Left sleeve with rank insignia velcro and partially sewed up pocket
Elbow padding
Arm pit
Back
As usual, velcro to tighten the sleeves at the wrists
The gloves remind me on the former SS067 FBI. Paintjob seems to be more shiny again and the wrists are a bit weak for DAM standards, but seem to be fine for now.
IMG_6232
The tag
Same belt as the 78052 Snow Leopard with great detail.
Pants with a lot of padding. Please note that you might see some cloth boots here, since some pics are taken from my earlier 78052 review.
Side pockets
Butt pockets are not fake
Reinforced crotch
Kneepads with padding
Pockets at thigh height. The right side has male velcro attached to it to hold the holster in place, which works well.
Option to tighten the pants at the knees
Pocket next to the ankles
Ankles
Boots are molded, which surprised me a bit as DAM didn’t do any molded boots since the 78024, if I remember correctly. This also means the nude comes without feet.
Sunglasses
Oakley
Again, same cap as 78052
The helmet is the one from the 78052, but without the cover and NVG mount and side rails attached
IMG_6291
No padding for the inside
Straps are slightly too long, which could have been prevented by providing inside padding. You could adjust the them, but this results in the strap hanging loose. Will be covered up by the throat protector anyway.
NVG mount with functions
IMG_6299
NVG
Side rails
And adapter for the light
X200
Complete helmet
NVG functions
IMG_6378
Same holster: pistol fits properly and it’s not too tight, which might rub off paint or scratch the item otherwise
Further items to attach to the duty belt
Canteen pouch
Gas mask pouch. With DAM I always wonder where the actual gas masks are, when they give you a pouch for it. Only figures I can remember were the SDU ones, but there you couldn’t remove the filter to fit the masks into the pouches.
Assembled
Vest
Closer look. I eventually needed to extend the waist straps on the body armor to be able to close the buckle.
Disassembling the plate carrier
IMG_6335
Throat protector. Attached the wrong way here. Front is at the rear.
The snaps (buttons) don’t fit perfectly, but do the job. Best working example here are DID products in my opinion.
The throat protector is attached to the vest by these loops and straps.
IMG_6374
Provided plates inside
Completely disassembled
All the pouches that will be attached to the plate carrier later
Med pouch
Rifle mag pouches
Double pistol mag pouch
Radio pouch
This time it wasn’t easy, but I discovered my first flaw, which is acceptable though. Later on the straps ripped and so I could assemble it correctly.
Velcro is sewed on the wrong way
Admin pouch
Double grenade pouch
Needs to be said, that most pouches had their straps sewed like this at the end. In this case it’s actually an advantage, because the straps tend to be too short sometimes and it works like barbs.
Assembled
The design of this vest requires you to fit the throat piece first
Then one by one the straps need to be attached
This is how it looks completed
IMG_6403
As the Type 15 armor doesn’t provide any female velcro, the black Snow Leopard and the largest patch contain straps for the molle webbing instead.
Canteen
FOR WATER ONLY
DO NOT APPLY CANTEEN
TO OPEN FLAME OR
BURNER PLATES
Watch
DAM’s overused Radio. I highly doubt that it’s due to the accuracy of this figure.
Protectors with straps. Should be exactly the same as the 78024 FSIN ones.
Unfortunately, they all come without velcro and elastic bands only , which makes it very hard to put on. It was a chore.
My suggestion for this now might be to remove the pants first, then put on the shin guards and try to slide through the nude legs at the end. This way less friction might be involved.
Forearm
Elbow
Shin and knee
Flexible at knee joint
Shield comes in two parts and is a new mold from DAM
Front
Back
Grip
Attached
Quite hard to make the hand grab the handle
Flashbang
QSZ-92. This is directly from my other review, since it’s exactly the same pistol
3
Mags
Comparison to Soldier Story
QBZ-95 partly from my older DAM 78052 review
Please note that DAM only provides 3+1 mags, so one less than you need to fill all pouches. I got one extra loose. But after I realized I have no pouches for the QCQ-05 mags, I removed the extra QBZ mag again to make space for two QCQ ones.
Plain rifle can’t be disassembled like it’s counterpart from World Weapons or Soldier Story.
Working charging handle, but not spring operated
Barrel
Magwell
Stock
Top rail
Detachable rails
Side rails
Rail adapter to slide onto the existing top rail attached to the carrying handle to fit others than the usual QBZ scope.
Scope. Only function is to open the flaps. Sunshade can’t be removed.
Magnifier
Light
Mag
5.8
Shell catch
Attach like this
IMG_6463
Then add the actual catch pouch
Open to release shells
I won’t do any comparison to the Soldier Story QBZ-95 here, as this one looks like it can be fully disassembled and I wanna save that for another review.
Fully geared
QCQ-05
This reminds me on the 78047A figure with the MP9, where the sidearm was the actual weapon people were waiting for, including me.
I was quite surprised seeing removable pins to disassemble this one.
Unfortunately, the only thing it’s doing is opening the stock to remove the spring.
Plain smg
Working charging handle, but difficult to show off with one hand on the camera, as it’s spring loaded and I was afraid of scratching the paint
Serial number
Working fire selector
Can be removed
Barrel (out of focus, will take a new one)
Carrying handle with rail. You might be even able to attach a scope, but the rail is thinner than the QBZ one, so no parts can be exchanged here.
Iron sights
Mag
Silencer
Silencer attaches very smothly
Complete figure
IMG_6523 IMG_6529
Quite similar to the first DAM Snow Leopard on the first sight, but other than the uniform and pistol, it has good variation and new parts. Many will be happy with the QCQ finally made and with such great detail. Also the highly used QBZ comes with different options now, as they added more rails.
A lot of westerners most likely will dislike this as a whole. For me, however, it adds good variety to my police collection. ButI am fine with Chinese by now, as it’s my fourth figure already and am looking forward to the coming Russians and the RAID.
I’ve got this figure on order, it has a lot of promise. A good entry for international LE and CT figure collections.
