DEVGRU N4 .300 Assault Rifle
T2 Micro Red Dot Sight
XPS3 Halo Sight
G33 Magnifier
Flip Mounts and Riser System
Sandman 7.62 Suppressor
Offset Mounted M600 Tactical Light with Remote
Iron Sight
Mlok Angled Fore Grip(AFG)
NGAL PEQ Indicator
30RD .300 Pmag
P320 XS 9mm Pistol
RMR Mini Red Dot Sight
XC2 Weapon Light
7377 als Holster with Cover
Pistol Mag with Mag Cap
8005A Assault Backpack
EXFIL Ballistic High Cut Helmet
L4G24 NVG Mount
AN/PVS-31 NVG
Tac Charge Pro Helmet Light
Matbock Tarsier Eclipse
Elite Ops Tactical Helmet Camera System
G Watch
Blast Gauge
S7 Tactical Terminal with Protective Case
Ball Pen
Sharpie Marker
Tactical Compass
SI Shocktube Sunglasses
IR Chem Light
65FROG SF Personal Retention Lanyard
We are also getting a newly-tooled Sig P320 X5. Weird plate between the red dot and the slide - I think the red dot can mount directly to the slide on the 1:1? Will have to see if I can remove the plate from the equation.
As Adam has pointed out, the Noveske’s lower is missing the “spike” on the lower right side of the mag release fencing - nearly all AR-15-pattern rifles have this spike. A weird detail for E&S to omit.
Edit, some generations of the N4 do not have a spike. Not sure if this E&S rifle matches what SF units are trialing, but it’s close enough for me. This might be kind of a frankengun as the spike-less 1:1 Noveske lowers (gen 3?) do not have the same angular trigger guard.
In 1:1 the rds does mount on a weird plate like this it seams, sigs solution for a rds doesn’t seem as sleek as glocks mos slides although I’m sure if someone really wanted a direct mount they could have a gunsmith do the cut, heres a pic of the mount in 1:1 it could also be a length thing, the glock has more room between the ejection port and rear of the slide where the sig doesn’t appear to have enough room for a rds cut
I did see that, but I saw even more evidence of red dots mounting directly to the Sig’s slide. So even if this adapter plate exists in 1:1, I’m still going to try and ditch it.
I agreed, the adapter plates are ugly, they are on the glocks too, I like the lower profile slide cuts a lot more, I was just looking at noveske s and both their gen 3 and gen 4 lowers do not appear to have the spike below the gate, I’m actually pretty shocked that e&s were pretty accurate with the upper and lower for this rifle, noveskes are unique receivers, I’m supprised they didn’t just resuse an existing generic mold
I could bet they will come in black too. Otherwise you can easily paint them. No markings on the receivers or handguard from what i can see. Just on the dust cover but this already black .
Guess I’ll wait until then. I’d do the same for the pistols but I already have some kitted DAM G17s for my DEVGRU figures to use. I might at least get the holsters, assuming that they can fit G34s or 19s at least. I also like the helmet and radio setup. Is there a way that I could safely remove the rails and mount so that I can repaint the helmet white?
Lowers are Gen 1 on the contract guns, upper is Gen 3. They likely used this one as the one they (ES) have with the correct profile has a KAC style trigger guard whereas this one resembles the MOE trigger guard on the contract guns.
Other details that can be changed without retooling.
Correct barrel color
Correct end cap color for the Dead Air (Tan end caps for contract guns are their training ones):
My CAG sniper already has a tomahawk like this from the 26040 figure, but since they (at least in my head) are half Native American, would it make more sense to switch it for the tribal one from this figure?
P320 X5 has an optic cut for their Romeo 1 or the Delta Point Pro, others would use an adapter plate. From the profile of the slide it looks like ES has replicated the cut. Docter sight and the strange adapter plate are an odd choice here.
MOE SL stock is also an odd choice as the SL-K are the correct stocks for the contract guns.
Ah, that explains the description. I probably could have Googled that right? If you want to see something funny, check this Tarzier video out. True Facts About The Tarsier - YouTube
Thanks. I don’t know if there is a headsculpt that looks like Krasinsky… I’d love to bash a 13 hours main characters but haven’t been able to spot this guy…
