Easy & Simple SAS CRW Urban Raid
Easy & Simple
  • 26022R
Body
  • Head Sculpt
  • ES-Buddy 2.0 Body w/ Tattoos
  • Oakley SI Assault Gloves
Uniform
  • T-Shirt
  • Tactical Pants
  • SCARPA Kailash GTX Boots
  • Ops-Core FAST Maritime Super High Cut Ballistic Helmet w/ Cover
    • Wilcox L4 G24 NVG Mount
    • AN/PVS-15 NVG
    • Core Survival HEL-STAR 6 Gen III Helmet Mounted LED Light
    • NVG Counter Weight Pouch
  • Tactical Protective Mask
Vest and Pouches
  • Crye Precision JPC
    • Crye Precision MBITR Radio Pouch x2
    • GP Pouch
    • Medic Pouch
    • FastMag ITW Nexus Gen3 Pistol Mag Holder x2
    • Crye Precision Frag Pouch
    • Crye Precision Smoke Grenade Pouch
    • Crye Precision Flashbang Pouch
    • Dump Rouch
  • Utility Belt w/ MOLLE Webbing
  • Omega Pacific Locking D Carabiner
  • GARMIN Foretrex 401 GPS
  • Casio G-Shock GPW-1000T
  • FNH USA Bawidamann Knife w/ Custom Kydex Sheath
  • Light Sticks (YELLOW) x4
  • Medical Sheers
  • Backpack w/ Signal Jammer
Communications
  • AN/PRC-152 Multiband Handheld Radio (Harris Falcon III)
    • Z-Tactical SELEX TACMIC CT5 PTT
    • Folding Antenna
    • 3M PELTOR COMTAC III Tactical Headset w/ ACR Adapter
  • Colt Canada L119A2 :canada:
    • SureFire FH556-215A Flash Hider
    • Magpul CTR Stock
    • Magpul EMAG 5.56×45mm (30rd) x1+1
    • NATO STANAG Mag 5.56×45mm (30rd) x3
    • Trijicon ACOG TA01 Rifle Scope 4x32 w/ RMR Sight, TA51 Mount and Tenebraex Killflash
    • EOTech ATPIAL LA-5/PEQ
    • SureFire M600 Tactical Light
    • SureFire SOCOM556 Suppressor
    • Magpul AFG-2 Angled Fore Grip
    • Sling Mount
    • Tactical Sling
  • Glock-17 :austria:
    • Pistol Mag w/ Mag Base Pad (BLK) 9×19mm (17rd) x2+1
    • G-Code XST RTI Kydex Holster
  • M-84 Stun Grenade
  • L132A1 Smoke Grenade
  • L109A2 Frag Granade
  • Union Jack
  • Call Sign patch
  • Royal Crown Patch
The new E&S box looks like this. It’s very slim, but doesn’t has to mean less gear for ES figures in general.
Out of the box the carrier was applied already
Who is that?
The new 2.0 body has much stiffer joints than the 1.0.
The connection of elbow and upper arm looks strange in certain positions. If you are nitpicking, the tattoos don’t match the ref pics.
T-shirt has a small collar and can’t be fitted onto a mannequin
Boots are just fine for moulded ones
The gloved hands have like the previous DAM models a nice matt painting and therefore look more life like
The problem with ES hands are though, that their grip is very loose and they tend to drop the rifles they are carrying
Belt and pants
Pants turned out awesome. No fake pockets and the cloth looks great.
Fake buttons here
Are these openings for ventilation?
Plate carrier reminds me on the DAM FBI figures
Stretchy material on the back
The inside
Not greedy here. Front and back have plates inserted
Side pouches
Attached like this
GP pouch
Annoying are the new doubled molle webbing straps. Mostly they were just too thick to attach the pouches properly and a lot of force was needed
Several grenade pouches
Pistol FAST mag holders look incredible. Only drawback the mags are sitting in very loosely
To attach push this rubber band downwards
Then you are able to unhook this flap
After attaching it to the vest put the flap around the hook again and tighten the rubber band
Completed vest. I realized later that the two side pouches were meant to be located under the molle webbing that closes via velcro on the front
Utility belt with molle webbings
Holster
G-CODE RTI
www.range5.com
PATPEND GA-0025
Med pouch
Drop pouch folded
Unfolded
Completed belt
Helmet
NVG counter weight
NVG mount
NVG
Night Vision Device
Model M953
(AN/PVS-15)
Serial NO.40726
Strobe light
Sticky tape
Headphones
The new foldable headphones. Unfortunately they are positioned in such an angle when attached to the helmet that you can’t use this feature
Completed helmet without headphones
Face mask. I don’t like it. Several units were using it during the Manchester bombing incident, but not this particular guy here. I am quite strict about being accurate on this occasion, because every difference would be pure laziness in my opinion.
Signal jammer with backpack
Like several users mentioned the zipper is too tight to open
Inside seems to be a wooden block or similiar. Peek through this hole to see
Carabiner
Watch
Sheers
Wrist GPS
Speed cuffs
Light sticks
Radio
Antenna
Knife is executed very well and secured in the sheath via a strap you can open
L132A1
M84
L109A2
No reason to highlight anything here anymore, it’s a G-17
Mags with base, which can’t be removed as I tried
This remake of the rifle I like much more than the former
camo version
Plain L129A2
Magpul logo
Wording
Disassembly
The charging handle looks and works like this
STANAG
EMAG
Mag holder
In comparison to the SS067 FBI HRT this one fits perfectly
Laser
Foregrip
Silencer
Light
Sticky tape
Sling mount
Sling
ACOG
Geared up rifle
Light switch with sticky tape applied to the rifle will most likely be irreversible. It either damages the paint or won’t be sticky anymore after once removed
Full figure with some changes. I didn’t use the carabiner, sheers, sling, sling mount and NVG as I couldn’t see it anywhere on the guy in the pics. I also custom made a respirator that is closer to the original. However, the patch and double mag holder I applied despite of the ref pics, because I just like the look of it.
I will use light sticks, but have to buy larger ones that actually have a big enough hole to fit a thread through as seen here (ES sticks can’t fit a thread)
Completed figure
Need to be said that the preview pics didn’t do this figure any justice. The whole package looks better in real life.
Also the L129 rifle, the pants, grenades and chest rig are perfectly executed in my eyes.
Less gear is actually a welcome and also had a nice Effect on the asking price for this one.
Personal drawback is the face mask and the holster.
Small niggles are the light sticks and tattos.
Respirator is based on this from the MSE Z.E.R.T. Z Squadron Sniper Team
grafik
EDIT
Sticky tape from the gun light is too weak and doesn’t hold properly on the rifle!
Updated gear
No NVG mount
Carabiner
Light sticks and ES 26027 holster will follow!
EDIT 2
Excellent review once again chpo. Keep it up, these are much appreciated.
Nice review chpo. Got a few parts on the way from this set. Still wish ES would give us better gloves and footwear for the price they’re asking.
Excellent in depth review. I hadn’t really fancied this figure but now after reading this I’ve changed my mind :smile:
Thanks. There’s always quite some work involved, but it’s fun. As long you all like it and it helps you out I am happy!
ES should step up their presentation :slight_smile:
Here is actually a good video of this guy. I just spotted the cable that connects the headphones is secured at the NVG counter weight pouch. The carabiner is attached to the back of the vest, left shoulder strap. He is actually using a rifle sling and not so important, but he is quite short.
Still can’t figure out if he’s wearing a gas mask or just a respirator with ballistic glasses.
Many thanks for the link to the video.
I have some screenshots from it.
Another screenshot.
No ballistic glasses!
grafik
Thanks for another awesome review!
