Flagset Sayeret Matkal Gear Review
Flagset
Uniform:
  • Keela IDF Tactical Combat Shirt (Limited Edition)
  • Keela IDF Tactical Combat Pants (Limited Edition)
    • LBT 0612A Riggers Belt
  • Agilite Gear Front Toward Enemy T-Shirt
Headgear:
  • Ops-Core FAST ST High Cut Ballistic Helmet
    • Agilite Gear Raptor FAST Helmet Cover
    • Agilite Gear Visor Nocturn Goggles Cover
    • L3 AN/PVS-15 Night Vision Binoculars w/ Wilcox L4 G24 Mount
    • NVG Eyecup (Pair)
    • S&S Precision Manta Strobe
    • Agilite Gear Mitznefet
  • Superman/Batman Cap
  • Petzl TacTikka Plus LED Rescue Headlamp
  • Sunglasses
Vest and Pouches:
  • Agilite Gear K5 Plate Carrier
    • Agilite Gear Ammo & Battery Pouch x2
    • Agilite Gear Contractor Ammo Pouch
    • Agilite Gear Advanced Ammo Pouch
    • Radio Pouch
    • Agilite Gear NVGT (Night Vision Goggles Binoculars Tether)
    • Water Bottle Holder
    • Medic Pouch
    • Grenade Pouch x2
  • Agilite Gear AMAP II Backpack
  • Dump Pouch
  • Drop Leg Pouch
  • Drop Leg Panel
    • Holster
    • Small Pouch x2
Tactical Gear:
  • PIG Full Dexterity Tactical (FDT) Alpha Gloves Gen 2
  • Agilite Gear Axis Knee Pads
  • Agilite Gear Felxible Assault Ladder
  • Light Stick (Pink) x3
  • Yates Gear-565 Helo Personal Retention Lanyard
  • Carabiner
  • Shemagh
  • Aquafina Mineral Water 16.9 oz
  • Map
Communications:
  • Harris Falcon III AN/PRC-152 Radio
    • MSA Sordin Supreme Pro-X Headset
    • Amplify Nexus U94 PTT
Weapons:
  • IWI Tavor TAR-21 :israel:
    • Magpul EMAG 5.56×45mm (30rd)
    • NATO STANAG Mag 5.56×45mm (30rd) x3
    • MEPRO MH3 M21 Day/Night Illuminated Reflex Sight
    • L3 EOTech ATPIAL (AN/PEQ-15)
    • FAB TAL-4 Tactical Vertical Foregrip
    • Silencer
    • Custom Rail Cover
    • IDF Rifle Sling
  • IWI Jericho 941 :israel:
    • Pistol Mag 9×19mm (15rd) x1+1
  • Folding Knife
  • M18 Colored Smoke Grenade
Patches:
  • Blood Type A+ Pos 2x
  • Israeli Flag Orange (Large)
  • Israeli Flag Green (Small) 2x
  • IDF Insignia Patch
  • Agilite Gear
  • Frog
  • IDF-Star
  • Patch (Limited Edition)
I already did a review of the D&K and DAM IDF gear, which was very comparable to each other due to similar parts and items. This one however contains several new and unique parts so I decided not to join them.
Please note that you can apply this kind of rule here were second tier companies are obviously able to produce nice cloth items, but are lacking quality with the plastic part execution.
Firstly, I am taking a look at the purchased clothing. I aquired the 1/10 suit and patch. This 1/10 practice is very stupid, if you ask me.
The clothing is very decent. Making comparisons to other brands is not always the way to go, but this one is almost on par with the top brands quality wise.
The torso material is made from a semi shiny material and feels much smoother then the sleeves, which have the rough cloth you know from the usual 1/6 BDUs.
The back
Sleeves
The flap for the shoulder badge is sewed onto the top, which is genuine accordingly to th ref pics I saw
Elbow area
Shoulder pocket
Cuffs with velcro
Exemplary zipper (The grey cloth is covering the nude body’s neck. Later, I opted for a neckless body, hence a better look without sth sticking out of the neck area of the uniform)
The top comes with this tiny pouch that attaches via velcro to the sleeve pockets
Wooden stick is used to indicate openings, like the tweezers
The pants are, like the top, a new addition to 1/6, if I am not mistaken.
The only shortcut I spotted so far is a part of the belt
Flagset didn’t make the effort to add a piece of velcro to this piece. Not sure what’s called, but I am used to attach the lanyards here on my models.
Pants with not even one fake pocket
Reinforced knee area
The food width comes with an interesting shape
Let’s get to the knee caps, which are fully functional, but lacking the Agilite brand logo
Straps are not detachable
They slide onto the leg quite easily and remain in place
They also support the full range of motion
Finally, the Agilite T-shirt. As the BDUs, it’s good quality, performs at least with a good fit on the mannequin and is provided with a proper print application as it seems so far (none of these cheap ones, that keep breaking and falling off after some time).
Gloves are unique
Cuffs can be tightened via this velcro band
Bungee loop to attach the gloves to a hook or sth similar
Shemagh made from thinner material than I am used to from Soldier Story e.g.
Did they try to save on costs here by only providing half a shemagh? :laughing: Realized later that the fit around the neck is easier with half a scarf, so no water needed.
The basecap has probably the best shape seen in 1/6
It won’t hold on a mannequin as the cap keeps sliiping off. Therefore I used a headsculpt to demonstarte the fit
Headlamp is basic
Can’t adjust the length of the strap, although it looks like
Sunglasses
The temples are not very flexible and barely fit the mannequin. Make sure to use a narrow face/head sculpt.
No details on the back side. Doesn’t matter though
Helmet set
Mitznefet looks very realistic and the colors merge nicely into each other
Other Mitznefets issued so far by D&K and DAM just differ so much and offer great variety
Here the basic FAST helmet with paint application flaws
Poorly applied velcro sticker
Chin strap
Fragile buckle
Agilite helmet cover and accessories
The counter weight pouch for the NVG
I added a pouch filler from another figure release as weight
Inner padding
NVG arm cover
Flap can be opened to use the NVG arm without removing the cover. The two flaps are secured by velcro and holding onto each other to remain in place.
Having this feature might imply that this NVG cover serves a similar purpose as the Mitznefet. To blur or erase the outline of a head/helmet of a soldier to make him less of an aim.
It’s attached like this
There is however no velcro or else to hold the cover in place, it’s just sitting there
NVG and arm mount
Wording is not well done but the WILCOX is visible
No other function than folding it open and closed
NVG
You can see the poor execution on this part especially well
Strobe light is basic quality
Positive is the velcro though. I recently checked all my figures and added velcro to all strobe lights with sticky tape only to make it removable. Sticky tape e.g. damaged the velcro on top of my SS085 helmet.
Another problem came up when I wanted to slide on the arm mount.
I am holding the rails of the arm directly next to the helmet mount and you can see by comparing the lenght of the two red lines that this discrepancy is definitely to large to slide it on.
However, the two blue lines indicate the amount of free floating material on the helmet. I compared this FAST helmet to others of my collection and realized that the rail on the helmet for the arm mount is too wide.
In order to fix this I bent the free floating material upwards as you can see in the left hand top corner. Easy enough as it’s super thin and makes me think it’s just excess material anyway that wasn’t removed before boxing the figure. Then I just cut it off with a hobby knife.
Attaching the NVG arm
Cover closed
Flap opened
It’s not exactly level
Radio and headphones
Detail is quite good
Flagset decided to attach a ligh stick to the antenna
Headphones
Execution is not on point, but fine
This cable is loose and just inserted like this
PTT and cable
Clip is very loose and won’t provide any secure hold
Drop leg panel
The plain panel
No buckle, but hey, at least you can’t break it then (unlike DAM 78058 drop leg panel)
There are these two pouches provided
A long and narrow one
And a square one
Holster
Mag pouch (no spare mag included in the box set)
Adjustable strap to secure the pistol
However, it’s sewed up anyway
And I couldn’t fit the pistol
Only way to cut it open
Now it fits
Mag inserted
Whatever this piece is good for. At least not for closing the holster
Completed leg panel.
Dropleg pouch
I got an extra belt you know already from the uniform in the beginning
Drop leg pouch and panel are attached here
Vest and pouches
Front opening
Back opening is secured with a string
The inside
Front zipper
It’s the opening to the space where the plate were supposed to be
Also no plate for the back
Detach like this, just by unhooking/unhinging
Opening the shoulder straps
I actually forgot to attach the dump pouch to the belt. So here it is
FIrstly the ammo pouches
Battery & Ammo
The real one fits 3 mags. This one is limited to 2, unless you squeeze them in really hard
I inserted light sticks here
I am thinking of adding SS085 batteries here
176
The advanced pouch only differs in this compartment. Maybe for an ID
Contractor pouch
I guess these are for grenades
So I added DAM M26 grenades
Med pouch
Both zippers give access to the same space
Radio pouch
Water bottle holder
NVGT
The velcro at the sides to attach it to the vest is very poor quality
The backpack
Originally comes with straps, but Flagset didn’t add any for this box set
Inside
Somehow all Israeli gear focusses on being able to carry a helmet
This is the way to attach the backpack to the vest, I guess
Completed vest
The lanyard is functional, but comes without any wording. Also the plastic quality is only medium as you can see and feel
Carabiner opens to the outside. Didn’t know these exist before. They are included with several Flagset releases
Water bottle
Nice feature to be able to open the screw top. No twisting needed, just pull it off
Small light sticks
They are light pink
Ladder
As you can see, they changed the design and moved away from the previewed item
Map shows the whole country. Israel is tiny, so this scale might be even useful
Pocket knife I have seen already with other releases, but I can’t recall which one
You probably need sth sharp to unfold the blade as my finger nails didn’t do the job
There is a tiny clip to attach it to a MOLLE webbing e.g.
Smoke grenade
941 Jericho
If you think you have seen this one already, you are not mistaken. It’s the D&K one.
IWI logo on both sides
No working parts as hammer or takedown lever
Only the slide is operatable
Iron sights
Mag
Tavor
As you can see, that next to the 941, the Tavor is straight from D&K, too
If you are going for execution and quality, then DAM will be definitely your Tavor choice. However, this differs slightly and might add variation to your collection.
The Flagset/D&K one has this unique rail at the handguard, which was initially meant for a under barrel GL. No company went there so far though.
Most pressing reason to buy this very rifle would be the tan color in my opinion.
Working charging handle, which is reasonable stiff. Fire selector is glued in
IWI logo
Barrel and handguard
Here the removable rail
Foldable iron sights
Rear sight is stuck due to paint on both of my rifles
Accessories
Foregrip
Rail cover with Israel flag. Very hard to find one with a level flag. Bad print application job most of the time.
MEPRO should be same from D&K. Even the lense comes in the same purple color.
Laser
Silencer
Good fit on the muzzle, but lack of details
Sling is asme s D&K
Small pocket
The hooks are rigid, so cannot be closed, but this bares no issue for me
The overlapping cloth is enough to keep them attached to the sling swivels and not fall off
The Tavor comes with 1 inserted EMAG
This rubber band is a poor attempt to make it remain in the magwell. At least they did something. I know enough brands that provide loose mags that fall straight out. As the band is very tight, I didn’t attempt to remove it for checking the hold without.
Ranger plate can be removed
The rest of the mags come as STANAG
Completed rifle
Finished and geared up
Flagset - DAM - D&K
If you wanna see DAM’s and D&K’s Tavors compared, click the Link to the Israeli gear review
I tried not to comment on the plastic items to much, unless there are major flaws or nice details, so consider all plastic gear Very Hot/Mini Times quality in general.
If you are into foreign forces you should be safe picking up a box set of this. As some parts suffer from certain flaws, others shine. What’s actually saving this figure is the unique gear and pretty neat Agilite Gear items.
Please note that I can’t comment on boots, headsculpt and body.
As a side note. D&K complained once about Flagset using their parts without permission. That was an accusation I didn’t really follow up on. So I am not sure, if Flagset owned the molds as an OEM and therefore had the rights to commercially use them. But it seems like that Flagset found a way in the end to makes use of the Tavor and Jericho molds without getting into too much trouble.
Impressive and comprehensive review once again chpo. Looks like a good set despite the quality on some of the plastics.
Impressive review again … with these close-up photos, you make me discover a number of unsuspected details that manufacturers offer … just perfect. :wink:
Full detailled review : Thanks for the sharing @chpo.
Where do you get this “grey” edition, please ?
Hey @Axi_Run, just picked it up somewhere on ebay directly after I saw this figure being released. Never spotted it anywhere else. As it is 1/10, which I hate, it will be similarly hard to obtain as the former M-069A MCToys green suit.
