Glue attachments to guns?
For this kind of works I use Vinavil: it’s a vinyl glue, easily removable that does not stain
In case of an error, or if you want to remove it, it allows you to do so
It’s a bit of an overkill because it claims it can hold up to 3kg :grin:
Easy to remove and color is gray which is very easy to blend in with most weapons. I also use this on other plastic or rubber accessories e.g. firmly attaching comm ear muffs to ears, fixing loose knife or gun into its sheath/holster etc.
