do you now, boys, if a Hot toys neckless head can fit on an Easy & Simple head connector ball (at the neck)? …Different types of E&S bodies? I want to buy a Hot toys Sir Alec Guinness headsculpt and E&S bodies are far cheaper than Hot toys ones.
Ball joint is larger diameter on the ES body so you may need a swap of the plug inside the Hot Toys head as well as modification to it to make the head sit at the right height. You might want to look at bodies that target the “custom” (aka bootleg) head sculpt market as those follow Hot Toys sizing.
