How to close cracks/gaps to fix unaligned handguards?
I need to help to acquire the above result without holding it in place. I considered several options already, but want to prevent having visible gluse stains all over the place.
Removing handguard not possible without breaking it off.
Hair dyer - give gun a blast (get it nice n hot) - hold part in place u want it to stay in (1/2 mins)
Maybe repeat for correct position
Good luck
Thanks, will give it a try!
Forgot - another method on same theme - is put rifle into boiling water, take out and push/hold part into place. Again hold in place 1/2 mins
I tend not to use this method as its messy.
Rgds
BigD
Glue Dot on the inside and under the barrel and then pressed up against it [the barrel], or Scotch grey “mounting putty” [like blue fun tac, only grey].
Thanks you two @BigD @BravoBob. Will check out both when I got time!
EDIT
I tried @BigD 's method with a hair drier first as it didn’t require buying any material and worked like a charm.
