Review DAM SOBR Lynx Operator PART 2
Click to get back
Handgun is the APB (APS with silencer adapter)
I realized they should have provided one more pistol mag as you have two taco pouches and the extra pouch attached to the holster and you can only fill two of them with the existing mags
Silencer
Mags are more or less the same except for the main one having a painted floor plate
Complete pistol
It’s the same as the earlier 78021 pistol
Of course, you can fit any stock released by DAM before
Click here for a DAM APS/APB comparison review
AS Val also seen before with the 78021
I am so disappointed this didn’t receive more attention.
You can only move the fire selector, but not the charging handle
Folding stock
Top
Muzzle
I have three of these AS Vals, but I only with one I managed to move the muzzle, which gives you a huge advantage when attaching the 78021 sling. You are probably not supposed to remove it completely, but the first two pics definitely show an intended function. I highlighted the pin and notch that slot into each other
Base rifle
Makes me want to finally have this in my hands, but you will never know when it’s released
It comes with 4 mags
Main mag has the same camo coloring as the rifle
I have no knowledge about the rifles features, but iron sights are solely featured at the suppressor
When in action, I have never seen any pictures where it’s used without the suppressor. At least, next to the sounds suppression, it must have an effect on the range and speed of the projectile
Here is the PSO optic with wording
ВКЛ (VKL)
ВЬІКЛ (VIKL)
The cap seems to be glued to the scope or at least caused by the paint. With the older 78021 you could just remove it
Here the eye piece
Before I go one here is a quick comparison to the 78021 non-painted version
Taking this picture now before applying the scope is crucial, as you most likely won’t be able detach it on a later stage without any damage.
DAM opted for the following mechanism as they didn’t replicate the original one (highlighted with blue lines; kind of a rail system).
There are two pins. The longer one on the left is responsible for the tight fit. The smaller one only adjusts the scope tosit in a proper position. This long pin however, sits very tight. You might be able to file it before inserting, but could effect the fit and then you are done.
Looks like Hobby Nuts found a way to implement the real one by the way. The rifle is still a prototype now for longe rthan a year
Completed rifle
At the end a short introduction about the sling. You can see that one loop is only wrapped around the sling
But it’s meant to be threaded through this metal loop/swivel
In order to do this it’s required to bend the swivel, because all loose ends (highlighted) of the sling are sewed up!
Fortunately, a quick fix
Quite interesting to see that DAM tends to deliver figures now where the secondary weapon is more interesing than the main one, when the figure comes with two weapons next to the pistol. I witnessed this with the 78047A (TMP-9), the 78061 (GL06) and now this 78059 (PP-19-01)
The Vityaz should be a piece many collectors have waited for and then it even comes in premium quality
The plain smg
As almost all DAM Russian rifles, you can remove the muzzle
Notch to install it in the proper position
SMG itself
It comes with a top and side rail, which would enable you to use all kinds of Russian optics here
Folded stock
Fire selector
Charging handle
You can open thebolt cover, but it requires to move the charging handle back for half an inch, otherwise it’s blocking each other.
I didn’t dare to push too hard
Rear iron sight is actually movable
Muzzles
Fortunately, my rail is installed properly and not crooked
Bottom
It’s no huge downside, but the mags are sitting slightly loose
Equipment
Mepro dight
Laser and switch
The Klesh was slightly improved by a velcro patch with the 78058
2ПС+ЛЦУ OOO “ЗЕНИТ” (2PS+LCU OOO “ZENIT”)
КЛЕЩ www.zenitco.ru (KLESH www.zenitco.ru)
N° 20857 Сделано в России (N° 20857 Sdelano v Rossii)
Detachable switch
Grip with rail. Rail sits too loose though and needs some work to sit tighter. Same for the laser. This is something I never encountered with DAM before. DAM’s execution used to be very good so far
This grip can’t be installed by itself
Mags
Sling
Completed
It’s almost finished now and only the completed figure pics left
Sling is attached to the silver carabiner
This buckle actually broke, but because I stepped on it
:heavy_check_mark:
  • New items like Vityaz SMG, new light sticks, specific Gorka suit and well done headsculpt
  • Assembly process bears little issues (not a given)
  • Rys-T helmet with radio connection
  • Topic never covered before by any other brand
  • 2 main weapons
  • Relaxed hands
:heavy_minus_sign:
  • Better QC than 78058, also plastic buckles are much more durable compared to the 78058
  • AS Val still without working charging handle (the RPK from a former Gangster Kingdom figure didn’t have it either, but was changed for later DAM releases)
  • Patches partially with velcro (it’s a positive, but putting this as a pro would feel inappropriate, as it should be the normal thing)
:x:
  • No grenades and 4th pistol mag provided
  • Helmet cable can’t be detached
Top full detailled review chpo.
Agreed about the AS VAL. However I do think it’s awesome that the weapons that came with this set are very sturdy, don’t suffer from upturned barrels and the folding stocks don’t collapse too easily.
Also, if you don’t like the tightness of the Gorka in certain places there are places you can reach in with an Xacto blade and cut the elastic to loosen it.
Thanks for that. Will do the 78061 or 78063, when they arrive in a few weeks.
Thank you for this review in great detail … :blush:
You are very welcome!
